BladeFireLight
Jan 17, 2022Aspirant
Ipv6 Lan not working
My isp uses piv6 dhcp-pd to deligate ipv6 My rax50 gets the prefix and does gateway advertisements but is not responding to autoconfig or ipv6 dhcp Support had me factory reset and I got the same th...
Jan 17, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
