BladeFireLight
Jan 17, 2022Aspirant
Ipv6 not working
My isp uses piv6 dhcp-pd to delegate ipv6 My rax50 gets the prefix and does gateway advertisements but is not responding to autoconfig or ipv6 dhcp Support had me factory reset and I got the same th...
Jan 17, 2022Guru - Experienced User
what modem/gateway is the RAX connected to?
- BladeFireLightJan 17, 2022AspirantAris surfboard sb8200 I have the prefix deligation from the isp with a /64
The problem is LAN side. It shows a /180 assigned
My devices get the gateway (linklocal of rax50) and dns server (rax Lans side routable ipv6) but not a routable 2600: address- BladeFireLightJan 17, 2022Aspirant
- plemansJan 18, 2022Guru - Experienced User
You expect the wan and the lan IPv6 addresses to be different. the wan side is the public ip address the ISP assigns.
