BladeFireLight
Jan 17, 2022Aspirant
Ipv6 not working
My isp uses piv6 dhcp-pd to delegate ipv6 My rax50 gets the prefix and does gateway advertisements but is not responding to autoconfig or ipv6 dhcp Support had me factory reset and I got the same th...
BladeFireLight
Aris surfboard sb8200 I have the prefix deligation from the isp with a /64
The problem is LAN side. It shows a /180 assigned
My devices get the gateway (linklocal of rax50) and dns server (rax Lans side routable ipv6) but not a routable 2600: address
BladeFireLight
- plemansJan 18, 2022Guru - Experienced User
You expect the wan and the lan IPv6 addresses to be different. the wan side is the public ip address the ISP assigns.
- BladeFireLightJan 19, 2022Aspirant
what I expect is my PC to be told by the router advertizment what prefix to use and if it's going to use DCHPv6 or SLAC
but that does not seem to be hapening.
