JohnDiV
Jul 03, 2020Star
IPV6 on RAX200 router not working after 1.0.2.88 and 1.0.2.92 Update
IPV6 on RAX200 router not working after 1.0.2.88 or 1.0.2.92 Updates. This router is connected to the Netgear CM-1150 Modem. My provider is Comcast. Had to roll back to a previous 1.0.2.8 firmware ...
Christian_R
Jul 08, 2020NETGEAR Employee Retired
Hello JohnDiV,
I may have a trial firmware that may help resolve your issue. If you're interested, please send me a private message with your email address and serial number.
Christian
- William3087Jul 09, 2020AspirantHaving same problem the entire firmware is broken even the Bitdefender security
- rinthosJul 09, 2020Luminary
Christian_R wrote:Hello JohnDiV,
Christian
+1 to Christian_R's offer. If you're blocked due to IPv6, his trial firmware version seems to do the trick, at least verified w/ DHCP-based IPv6 (such as most Comcast and Xfinity plans). Seems specifically just for this issue I believe...
Thanks for helping Christian!
- RajaDajaJul 11, 2020Luminary
Hey Christian_R,
Please send this firmware, I need it again, lost the previous one you sent me. Thanks
- JohnDiVJul 10, 2020Star
Thank You Christian !
- William3087Jul 11, 2020Aspirant
can i gave the trial firmware having same problem
- lmanpunkJul 11, 2020Star
- William3087Jul 12, 2020Aspirant
i did updated abd still didint work
