motion4life
May 10, 2023Aspirant
IPv6 Port forwarding
I see the options to enable ipv6, but i don't see anything about port forwarding with ipv6. i'm trying to setup my server to be able to use ipv4 and ipv6. Any help would be appreciated. Thanks...
microchip8
May 10, 2023Master
There is no NAT in IPv6. The address you get is a public one, so there is no NAT and no need for port forwarding.
- motion4lifeMay 10, 2023Aspirant
do i need to enable ipv6 on the router then? what option should i select so that it can be open?
Disabled
Auto Detect
6to4 Tunnel
Pass Through
Fixed
DHCP
PPPoE
Auto Config
6rd
- microchip8May 10, 2023MasterIf you want an IPv6 address, of course you have to enable IPv6. Start with "Auto Detect".
Do note that the router has an IPv6 firewall that can't be configured by the user. So if you need to open a port for a server, you won't be able to on router level.- michaelkenwardMay 11, 2023Guru - Experienced User
microchip8 wrote:
If you want an IPv6 address, of course you have to enable IPv6. Start with "Auto Detect".Good advice. It worked for me.
It could also help if we knew which ISP this is and the router involved.
ISPs have different implementations of IPv6.
Not all routers support all variations.
