athene20's avatar
athene20
Is it genuine netgear?
I recently purchased RAX50 from China. I bought RAX40 before, but I wonder if it's genuine because the box design is different. I'm attaching the picture of the model I just received. It has a sliding cover and is packaged in an unprinted plain box inside.
  • plemans's avatar
    could just be it was at a different location since its a china region device.
    Are you in the china region? Some devices are region locked and it can create issues if you use them outside of that region.
    • athene20's avatar
      athene20
      I don't live in China, but I already know about it. I'm going to try it because I heard that it is possible to unlock the region lock after connecting to the console with TTY.
      Does Netgear sell products in boxes like that?
      • plemans's avatar
        I've gotten ones in white boxes and brown boxes. About all you can do is open it up and find out
