cyruslego
Oct 02, 2019Aspirant
Is it normal my iPhone 11 Pro's wifi speed limited to ~450Mbps when i connect to AX8 5GHz?
I just bought AX8 yesterday and I connected to 5GHz and the results were all limited to around 450Mbps (451 highest), is it because of the channel i chose? (I'm using 160), and which chnnel or settin...
Oct 03, 2019Guru - Experienced User
to use the full 160hrz spectrum you need to be using the dfs channels. so make sure that 160hrz is enabled, that you've selected 4800mbps, and that you select the lower spectrum 5ghz channels so you can utilize dfs. I could be wrong but my understanding was that if you select the higher 5ghz channels, it auto selects 2400mbps and not 4800mbps.
