cyruslego
Oct 02, 2019Aspirant
Is it normal my iPhone 11 Pro's wifi speed limited to ~450Mbps when i connect to AX8 5GHz?
I just bought AX8 yesterday and I connected to 5GHz and the results were all limited to around 450Mbps (451 highest), is it because of the channel i chose? (I'm using 160), and which chnnel or settin...
avtella
Oct 03, 2019Prodigy
If I recall correctly, the iPhone 11 does not support HT160 it’s HT80 only. Also I believe there are some issues with the WiFi firmware that were supposed to be fixed on the iPhone 11 in the recent .1 iOS update.
If it’s any solace, either way I doubt it makes much of a difference on a mobile device as you’d realistically probably never use anywhere close to that much bandwidth on a phone at any given time other than benchmarks like Ookla or DSL Reports.
Oct 03, 2019Guru - Experienced User
thanks, I'm not an apple guy so wasn't aware of the Iphone limitations.
- avtellaOct 03, 2019ProdigyAlso note that WiFi-6 will realistically only give you like 5-10% increase in performance over WiFi-5, and maybe up to 15-20% in rare cases as 1024QAM is more sensitive to noise so don’t expect to be at max link rate all the time. WiFi-6 is more about better spectrum sharing especially in multi AP/router environments allowing for better performance in signal dense situations.
450 Mbps is actually pretty decent benchmark and, and also depends how close you are to the router and how many walls/floors are between you and the router as well. I wouldn’t expect more than say 600-800 Mbps peak real world throughout and that too at close ranges.- cyruslegoOct 03, 2019AspirantGot it! Thanks so much for explaining that to me, i thought wifi6 will make my connection much faster
- plemansOct 03, 2019Guru - Experienced User
agree with avtella speed assessments and speed increases. you really aren't going to see a whole lot of change. Its more about handling multiple connection simultaneously.
450mbps is quite fantastic and other than updates or downloading large files, you're phone isn't even going to fully utilize that.
- cyruslegoOct 03, 2019AspirantYes i expected too much on wifi 6. And when i use my old iPad to test it’s a huge difference
- cyruslegoOct 03, 2019AspirantAlso the MU-MIMO do i need to enable it?
