illiad
Apr 20, 2022Tutor
Is it possible to transfer files from connected USB drive wirelessly to my android?
I have seen many post about using a Netgear router as a simple way to connect SSD storage. eg https://dongknows.com/turning-wi-fi-router-usb-port-into-a-nas-server/ (this is a 2 year old post, so t...
Apr 20, 2022Guru - Experienced User
You should be able to do this. I routinely transfer files from my phone to my nas. Its as simply as moving them using whatever app you choose on your phone to the hard drive. the phone should be able to see it as a network drive.
- illiadApr 20, 2022Tutor
** to clarify ***
I DO NOT HAVE A NAS...
I have a HDD, inside a case, powered externally. Please search the 'startech' website for s351bu313
this is connected to the Nighthawk RAX50 using the supplied USB 3.1 Gen 2 cable.
please check my question 🙂
- plemansApr 20, 2022Guru - Experienced User
I understand you don't have a nas.
Attaching the hard drive to the router makes a simple networked folder/drive. Same thing as a basic nas. (nas=network attached storage)
Concept is really similar. I usually use ES file explorer or File manager and then just add the networked drive in its settings.
- illiadApr 21, 2022Tutor
Thanks for understanding! 🙂 there are other websites that say it is not a 'real nas ' , that is why... 🙂
