illiad
Apr 20, 2022Tutor
Is it possible to transfer files from connected USB drive wirelessly to my android?
I have seen many post about using a Netgear router as a simple way to connect SSD storage. eg https://dongknows.com/turning-wi-fi-router-usb-port-into-a-nas-server/ (this is a 2 year old post, so t...
illiad
Apr 20, 2022Tutor
** to clarify ***
I DO NOT HAVE A NAS...
I have a HDD, inside a case, powered externally. Please search the 'startech' website for s351bu313
this is connected to the Nighthawk RAX50 using the supplied USB 3.1 Gen 2 cable.
please check my question 🙂
Apr 20, 2022Guru - Experienced User
I understand you don't have a nas.
Attaching the hard drive to the router makes a simple networked folder/drive. Same thing as a basic nas. (nas=network attached storage)
Concept is really similar. I usually use ES file explorer or File manager and then just add the networked drive in its settings.
- illiadApr 21, 2022Tutor
Thanks for understanding! 🙂 there are other websites that say it is not a 'real nas ' , that is why... 🙂
- plemansApr 21, 2022Guru - Experienced User
Its all depending on how you think of a NAS. The hard drive connected to a router is considered the "poor man's" nas for many.
But it does work. and for those just doing basic things, it works well. But if you're needing more speed/performance/automation, then looking to a dedicated NAS is a good option. I used the hard drive connected to my router for a quite a while before I wanted more capabilities and built a home server to handle it.
