Goldheart
Nov 09, 2021Aspirant
is Netgear nighthawk ax8 8 stream ax6600 vpn capable?
Just purchased the nighthawk ax8 wifi 6 6600 router... was told by best buy that I could install my express vpn on it... but when contacted express vpn they said that this particular netgear router i...
Nov 10, 2021Guru - Experienced User
There isn't.
ExpressVPN is 3rd party firmware that installs to a router. And expressvpn only supports a few routers. I haven't seen a single AX router from netgear supported on it.
Plus its 3rd party firmware and you wouldn't see anything about it on the official forums.
