bparkerb8
Mar 27, 2019Follower
Is the AX12 (RAX120) overkill for the "normal" home when compared to AX8?
I am going back and forth on if I should get the AX12 through the premier Beta program or just buy the AX8. I would say I have an average number of devices conncected to wifi (phones, tablets, camer...
schumaku
Mar 29, 2019Guru - Experienced User
bparkerb8 wrote:
My question is would I be able to even see a noticable difference with wifi performance from the AX8 and AX12 to justify getting the AX12?
Unless you have a number of sophisticated Wi-Fi 6 (802.1ax) clients where some difference on performance is possible, as long as you use the common 802.11ac and older 802.11n wireless clients, there won't be a difference from a good 802.11ac router.
