betens
Apr 26, 2022Follower
Is the Netgear Nighthawk RAX50 worth it?
The Nighthawk is currently at a fairly good discount at my local store, it has good reviews, but when looking it up on Reddit, there were a few posts stating that the router is "unstable". I.e droppi...
Apr 27, 2022Guru - Experienced User
You'll always see posts with people that have issues. They're always going to go on support forums/review sites to explain the issues you're having. So you'll never find something that has 100% good reviews.
I usually recommend to people to buy from a site/store that has a good return policy. Buy the device and give it a good week and if its not to your satisfaction. return it. Usually you can tell pretty quickly if something meets your needs or not.
- michaelkenwardApr 27, 2022Guru - Experienced User
Very true. This place attracts people with problems, not those with success stores to report.
Another place to look for views is on the sellers' sites/No one would ever trust Amazon, say, as the ultimate arbiter, but people will write reviews for things that they like as well as stuff that cause problems.
