gdahl7
Nov 26, 2020Follower
is the NIGHTHAWK® AX5200 AX6 DMZ capable
Hello, I would like the option for a DMZ. Will the NIGHTHAWK® AX5200 AX6 do this? Thanks, Gary
michaelkenward
Nov 27, 2020Guru - Experienced User
Visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.
You may have done this already, but I can't tell from your message.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
Is the Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
- microchip8Nov 27, 2020Master
Most NETGEAR routers support DMZ
