gdahl7
Nov 26, 2020Follower
is the NIGHTHAWK® AX5200 AX6 DMZ capable
Hello, I would like the option for a DMZ. Will the NIGHTHAWK® AX5200 AX6 do this? Thanks, Gary
michaelkenward
Nov 27, 2020Guru - Experienced User
Visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.
You may have done this already, but I can't tell from your message.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
Is the Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
microchip8
Nov 27, 2020Master
Most NETGEAR routers support DMZ
