rhys375
Apr 29, 2020Tutor
Is the Nighthawk RAX80 compatible with Australian FTTC NBN?
Hi all, I recently (FINALLY) got FTTC NBN activated at my home. In preperation of this event (upgrade from ADSL of less than 4 Mbps Down) I splurged and bought the Nighthawk AX8 router for my home...
- May 05, 2020
I believe the information I gave regarding the NBN NCD providing an ethernet connection is correct based on reading I had been doing accross multiple forums. As I said, it takes the VDSL signal from the FTTC splitter in the pit out the front of my house and effectively acts as a modem but it is not directly accessible by the user as it has no built-in PPPoE authentication ability so you cant just plug directly into it as far as I know. So yes, in fact all I needed was a router but I was seeking guidance on how to set it up to authenticate PPPoE with my ISP.
I am writing here for any future readers to tell you YES! It is compatible! All the other info I could find was for lower tier Netgear routers and the settings you need to alter are in different directories for the Nighthawk AX8.Interestingly, you do NOT need a password to satisfy your login credentials. On the internet setup page on the router home IP address just put in your username without the "@tpg.com.au" suffix. Set the ISP drop down menu to "PPPoE", leave password blank, leave service name blank, connection mode should be 'Always on', Get IP dynamically from ISP and I use 1.1.1.1 as my primary DNS and 8.8.8.8 as my secondary, though this can also be left as get automatically from ISP if you want.
All of that is straightforward, but heres the rub. Alone, it is not enough. You also need to alter the VLAN setting and there is a little trick to that. In the AX firmware you need to select the 'Advanced' tab at the top left of the page. Then select 'Advanced Setup' from the menu on the left hand side and finally select 'VLAN/Bridge Settings'. I dont know enough to say exactly WHY this set-up works, all I can say is that it does. The VLAN ID of 2 is specifically for TPG and I believe other ISP's use other VLAN ID's. As you can see, I have Port4 on its own group and all others on a different VLAN group. The reason for this is, any port that is associated with the group that has a VLAN ID of 2 and priority of Zero becomes inaccessible after you set this up. I was getting very frustrated because once I was swapping all my ports onto this VLAN Tag the internet light on my router was going from amber to white but it became impossible to access my router or internet via any IP address or even routerlogin.net. However, if I left my active ports on a secondary VLAN Tag with a priority of 2, BINGO, my AX8 was now working with no TP-LINK modem, my ping has dropped, my wifi speeds increased from about 37 Mbps to 47 Mbps on back-to-back runs between the budget router included from TPG to my AX8 Netgear router. Also wifi range was SIGNIFICANTLY increased and of course the addition of WIFI 6 which my next phone will almost certainly have.
I hope this info can help someone else. I probably lost a few years of my life trying every setting I could and resetting the router a million times but it was worth it in the end.
michaelkenward
Apr 30, 2020Guru - Experienced User
rhys375 wrote:
I recently (FINALLY) got FTTC NBN activated at my home. In preperation of this event (upgrade from ADSL of less than 4 Mbps Down) I splurged and bought the Nighthawk AX8 router for my home network. As far as I could tell when I bought it, the NBN connection box does all of the decoding and all I needed was a modem/router with an 'Internet' or 'WAN' port, which the AX8 has.
The RAX80 is a router. It usually sits behind a modem of some sort.
The type of modem depends on your internet sevirce, cable, DSL, fibre, something else.
FTTC NBN will need something to feed Internet to the RAX80.
Start here:
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
Note that it does not list FTTC, a label that gets used in different ways in different countries. Here in the UK it is usually stuck on a DSL service.
Ask your ISP what modems are compatible with its FTTC service.
Here's another good place to look for advice:
rhys375 wrote:
Meanwhile, the include free TP Link router is plug and play and works 100% perfectly. Any help would be greatly appreciated
Does it have a model number?
It is probably a modem/router. Does it have a setting to turn it into modem only (bridge) mode? If so you can put it in front of your RAX80. YOu dontl want two routers on the network.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
