Joelbronx
Apr 26, 2021Tutor
Is the RAX 50 Router compatible with COX Cable's Gigablast
I am assuming my RAX50 Router will work with the Gigablast speeds offered by COX cable. I have already confirmed that my Cable modem is.
Razor512
Apr 26, 2021Prodigy
Forgot to mntion, the speeds I mentioned are if you are largely in the same room as the router. As you move away from it, and go to other rooms, throughput will drop, though with 2 stream 802.11ax clients that support 160MHz channel width, they can maintain gigabit+ speeds for a good distance.
Joelbronx
Apr 26, 2021Tutor
Thanks Razor for both your emails!
