nchoodam
Dec 28, 2022Follower
Is there a WDS capability in Nighthawk AXE11000 model
Is there a WDS capability in Nighthawk AXE11000 model, If yes. how do i configure it in AP mode. I have another router which i need to connect to Nighthawk AXE11000. Kindly suggest.
michaelkenward
Dec 29, 2022Guru - Experienced User
Connect how? Wired or wifi?
Which AXE11000 are you talking about? RAXE500?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
