gworley1
Mar 08, 2023Aspirant
ISP says I should be getting 300 Mbs however only getting 100 Mbs
When I plug one PC into my Cable modem and configure the network card on the PC for my static IP - SPEEDTEST by Ookla reports that I am getting 370.68 Mbs down however with my RAX120 I am getting les...
Kitsap
Mar 08, 2023Master
gworley1 wrote:When I plug one PC into my Cable modem and configure the network card on the PC for my static IP - SPEEDTEST by Ookla reports that I am getting 370.68 Mbs down however with my RAX120 I am getting less than 100 Mbs -- last test 90.28 Mbs down. My upload speed is the same 11.82 Mbs.
Router:
Nighthawk® AX12 RAX120Firmware:Router Firmware Version V1.2.8.40The computer from the connection speed to the router is showing a 1Gbs connection as it is a wired connection using CAT 6e Ethernet cable 10 feet.Thank you in advance,George
What is the brand name and model number of the upstream cable modem connected to your RAX120?
By chance is it a combination cable modem/router device with several Ethernet output ports?
- gworley1Mar 09, 2023Aspirant
Router:
Nighthawk® AX12 RAX120Firmware:Router Firmware Version V1.2.8.40The computer from the connection speed to the router is showing a 1Gbs connection as it is a wired connection using CAT 6e Ethernet cable 10 feet.Thank you in advance,GeorgeWhat is the brand name and model number of the upstream cable modem connected to your RAX120?
Ubee DVW32CB 4 Ethernet ports.
I have tried all 4 of them.
Event tried the 5G port on the router.
George
- microchip8Mar 09, 2023MasterThat's a modem/router and since you didn't mention it, most likely you're in a double NAT situation(1) you should avoid. If you can, put the Ubee in bridge mode. If not, put the RAX router in AP mode.
(1) https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad - michaelkenwardMar 09, 2023Guru - Experienced User
gworley1 wrote:Ubee DVW32CB 4 Ethernet ports.
This might be useful:
ubee dvw32cb bridge mode - Google Search
- plemansMar 09, 2023Guru - Experienced User
You might check what the router is showing the lan/wan port connections at. maybe the computer is saying gigabit but the router isn't. (shouldn't work that way but stranger things have happened).
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
