Fain
Nov 18, 2020Follower
Issue with external switch and AX4
Same issue as here
Just bought this router AX4 and connected it all up.
All is working but an external switch that works with every other router I've owned.
The switch is a TrendNet TEG-S82g 8-port
Tried multiple ports on the AX4 with no luck.
1 Reply
- Christian_RNETGEAR Employee Retired
Hello Fain,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
