jguerdat
Nov 01, 2024Guru
Issue with OpenVPN on RAXE300
I recently had been getting ignorable errors when connecting via OpenVPN to my RAXE300 router but apparently a recent Android app update now has broken it completely. I tried downloading the .opvn setup for Android again with no success in getting that to work so I suppose that hasn't changed along with the app. I'll attach a screenshot of the error in case it helps. Any suggestions are appreciated.
- KitsapMaster
The most recent updates to the Android OpenVPN application added a number of custom setting options. If you do not review and set what you want, they take on the default setting that does not match what Netgear uses. Also review the advanced section at the very bottom of the settings screen.
Thanks for that. A question is how do I know what options to change and where they are? Not a VPN or network expert...
Edit: I do see that I could edit the .opvn file and eliminate the "dev-node" line (is there a way to comment-out the line?) - is that a Good Thing to do?
- KitsapMaster
jguerdat wrote:Thanks for that. A question is how do I know what options to change and where they are? Not a VPN or network expert...
The options you change are in the settings section of the mobile application. One page under settings and one page under advanced settings.
You may be into some trial and error, one setting at a time.
You can edit the ovpn file using a text editor. Once edited, you have to import it back into the mobile application.
For information on a specific line or command, use your web search.
The application for use on a Windows computer, generates a log file that highlights the errors.
