FeedMeTacos676
Dec 18, 2023Aspirant
Issues with iPhones and Wifi Devices
I'm at my wits end with my RAX70, I have a handful of iPhones with wifi issues (lag) when visiting youtube, reddit, and tik tok. When I play on my switch it disconnects on random games and other issu...
FeedMeTacos676
Firmware: V1.0.14.134
I am using my own router a SURFboard SB8200 with their CAT6A cables.
I am having issues on both 2.5 and 5Ghz so any changes have been useless.
I disabled the MAC randomizer on both iPhone and iPad and it didn't work!
If it is an iOS 17 issue, that is good to know, unfortunately it doesn't explain why my switch will lose network connectivity.
Dec 18, 2023Guru - Experienced User
Armor, Smart Parental Controls or Circle, Traffic Meter.
Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Try disabling AX mode on both 2.4 and 5Ghz radios.
Try disabling Smart Connect and set separate SSID names.
Try setting WPA2 and AES only.
- FeedMeTacos676Dec 18, 2023Aspirant
Thanks for the recommendations. I have already done most of this.
