Sitchey
Jun 04, 2023Aspirant
Issues with RAX200
Hi I have a nightwak rax200. I'm having a few issues which are either my broadband or router. My connection is constantly dropping in and out (both and LAN and wifi). I have a fibre 1g static IP b...
Kitsap
Jun 04, 2023Master
Sitchey wrote:
Hi
My connection is constantly dropping in and out (both and LAN and wifi). I have a fibre 1g static IP broadband connection. My supplier says the line is fine, which they would. I've started a ping tracker to monitor drop packets.
But I also want to run tests on my router plus setup reserve IP addresses on my LAN to make sure it's not device related.
I've went to the advanced setup area and followed the instructions for setting up. But Ive got some issues
1. The connection via the default IP for the Nighthawk is painfully slow. Even when i connect directly to the routers LAN it's very slow to load the admin pages. This is making me thing it is router related. Is that slow speed normal?
2. When I do wait and the pages load, I can only seem to create 2 reserve addresses? Is that right? When I have 2 and add any more it just replaces the last one created. Ive not got it selected to ask for one to be replaced, so again feel there is something going on.
Has anyone had similar issues with their router? And can you only have 2 reserved addresses?
Thanks
What device are you using to connect to your RAX200? Brand and model number would be helpful.
How are you connecting to your RAX200? Via Ethernet cable or over Wi-Fi. If Wi-Fi, what band, 2.4 or 5 GHz?
Do you have any of the following features activated on your RAX200? Dynamic QoS, traffic meter, Armor, smart connect, or access control?
Do you have IPv6 enabled?
Anything unusual with your DNS settings? Using the default from your ISP?
