Sphinx777
Jan 23, 2021Aspirant
Ive an Ax12 Rax200 - want to add an extender. AX6000, AX8, EAX80 or RBK850?
Afternoon all, some advise please if i may, ive found one other thread on here about an rax200 asking about an extender but is not the same as this question. Should this of been asked already, ...
Sphinx777
Feb 13, 2021Aspirant
Hi
Can you give me some more info please.
I’ve got the orbi rbk81 modem now with the satellites. How do I put it behind my night hawk and get it to work together. Is the orbi plugged into the pan port of the night hawk? Or does it need to to go to the modem and night hawk from the orbi lan. Thanks
Feb 14, 2021Guru - Experienced User
You're trying to go?
Modem--->RAX200----->Orbi RBK850?
Is that correct?
If so, put the orbi system in access point mode to prevent a double nat.
The RAX200 won't "integrate" into the system as part of the mesh but it will work as a seperate ssid/network you can use. I usually use mine for IoT devices and for peak performance streaming (because it'll have faster peak speads when you're close to it)
