trashernet
Sep 13, 2019Aspirant
Joke support
Whoa I have never been so frustrated trying to find a email to contact a company. Ridicously, anyways, Thanks for nothing Netgear I don't know whats wrong with this router but it seems to be unable t...
michaelkenward
Sep 14, 2019Guru - Experienced User
Retired_Member wrote:
Not to flame you. The router you have listed is not an AX model.
It is not even a router. It is a WiFi USB Adapter. But that is probably because this is the first "drop down" option when someone starts a new message.
As well, as finding the right section for the model involved, it also helps to provide the information that the community requests:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
The questions are there for a good reason.
Visit the support pages:
feed in the model number (find it on the label on the device) and get all the documentation for your hardware.
trashernet
Sep 14, 2019Aspirant
The model is
NETGEAR Nighthawk AX8 8-Stream WiFi 6 Router
I'm returning it because it proves to be unreliable and I can't find any guides to manage the settings to rectify the connection issue. My old router works prefectly fine so I know it isn't the ISP. Inconsistent network from a $400 dollar router out of the box. What the flip
- michaelkenwardSep 14, 2019Guru - Experienced User
