berlin433
May 15, 2023Aspirant
Just brought the nighthawk ax6000
So just brought a new router and I had the ASUS ac3000 and used a cheap ASUS router to air mesh. what do I use with the nighthawk to get better Wi-Fi range on my home any idea ? Thanks
May 15, 2023Guru - Experienced User
What actual router do you have? AX6000 is a speed.
What size is your home?
Is the router centrally located?
You can use extenders but I usually don't recommend using more than 1 of them. So I'm curious how big your home is.
