zadok1
Apr 11, 2021Aspirant
Just purchased RAX45 six channel. will not connect to Xbox One.
Old router was a Linksys EA7300 connected fine. How should th XBox be set to connect to new RAX45? or how should router be set to connect to XBox? Please keep it non-tech easy. I'm new at this kinda ...
thehypnootoad
Apr 12, 2021Luminary
Is the rax 45 replacing the old router? If so then can connect either wireless or wired ( wired is better option ) but if the router is too far or you don't want mess of cables wireless is more than enough. There is lots of option you can use to help if you live in busy household like qos. Dmz can prioritise your xbox and will normally open all ports but this can be a security risk . Port forwarding certain ports are normally used for things like strict nat types or a game causing connection problems due to ports.
- zadok1Apr 12, 2021Aspirant
Pk. Thx. How exactly do I do that?
- thehypnootoadApr 13, 2021LuminaryThose option are in the router settings 192.168.1.1 - enter admin password then got to advanced - wan should be there for dmz or advaned - qos.
