Twentyways
Jan 22, 2022Aspirant
Lan disconnect and reconnect ps5 on multiple rax routers
I have 4 ps5s at different houses and different states, it is not the Systems. They randomly lan disconnect and reconnect intermittently. It's either in the software from Playstation and how to handle...
Jan 24, 2022Guru - Experienced User
Something to contact Sony about and let them know what your seeing.
Twentyways
Jan 24, 2022Aspirant
Contacted Sony they have to contact netgear and work between the two about the systems and their communication and put out a hot fix... Only answer I've been able to find is a beta got fix that kills your speed by 80% and that's not acceptable to me or for gaming. netgear wants me to pay them for a troubleshooting or a solution that should be known or put out for netgear product owners. Just cause it's over 6 months and tech support on all my devices have expired. Terrible to pay for a solution to their product or the way it communicates with a gaming console
- TwentywaysJan 30, 2022AspirantStill no solution... Does netgear even chime in on the forums? This is definitely a communication issue between netgear products and ps5
- MilkMenaceFeb 16, 2022Aspirant
Try disabling IPV6 on your router.
