keys222's avatar
keys222
Tutor
Nov 10, 2019
LAN not getting GIG speed AC1900 or AX12
Hey everyone. Hoping someone can help here. I used to run an AC1900 and was fairly happy with it until I upgraded to Gig speed internet from FIOS (set up is fiber direct to ONT, Cat5e from ONT to router). The problem was that I was only getting ~300-450Mbps when I connected my main PC to the router via the Cat5e. Alternatively, when connecting straight to the ONT, my speeds were in the 900Mbps range. I did quite a bit of troubleshooting (turn off QoS, etc) but nothing seemed to help. I eventually got tired of the frustration and changed to an Asus AC3200 and it immediately gave me the Gig speeds on LAN that I knew I should be getting.
That setup has worked great over the last few years. However, I received the AX12 to do a test review. While the wireless speeds blow the ASUS  (and the AC1900) out of the water--and I'm super happy about that--as an afterthought I ran the speed test on my main PC which is hardwired. And guess what? I'm capped at 450Mbps. This is a brand new router and an expensive one, but again its Netgear and again the same problem with getting no Gig speeds on ethernet.
To summarize:
-Gig speeds direct to ONT
-Gig speeds via ASUS router
-300-450Mbs via Nighthawk AC1900
-450Mbs via Nighthawk AX12
What is wrong with this picture? Any ideas at all?
    • Ax12 is an RAX200 nighthawk he is referring to and yeah that capped speed is a broken glitch that somehow NETGEAR hasn’t yet addressed in the $600 router. I had to take mine back. The RAX120 is performing correctly though but crashes on some time machine ops
      • keys222's avatar
        keys222
        Tutor
        YoungSpicket I assume you tried without success to troubleshoot the issue (like me). How unfortunate--the wireless aspect really performs well, but it's intolerable that it cannot perform up to speed on the LAN side--I mean, this is 15-20year old tech that $50 devices can do without trouble. Oh well. Thanks for the response.
    • keys222's avatar
      keys222
      Tutor
      I appreciate the repsonse. Not sure where else to go as the AX12 has 'Nighthawk' written all over the box...
