DeeMac
May 26, 2022Follower
Laptop cant see nighthawk Ax2400
I need guidance...simple instructions. I believe the AX needs to be turned off?? Please help
May 26, 2022Guru - Experienced User
What model router do you have? AX2400 is a combined wifi speed.
Review the user manual for configuration settings for wifi features.
