Sparxnarx
Jan 18, 2020Aspirant
Laptops do not see RAX 80
I have 3 Dell laptops, all Intel AC 7260 wireless adapters. All older with new hard rides and recently updated to Windows 10 proffesional. My original had no problem connecting. Dell E5440. The 2 I j...
- Jan 18, 2020
Two thoughts. One the Intel drivers do not understand AX. Easy to figure out, disable AX on router and see if now attaches.
Other thing would be to be sure you have the latest Intel drivers for your laptop.
Sparxnarx
Was able to roll back driver in original and it works again! Unfortunately, I don't have that option with the other 2.
Sparxnarx
I will give the disabling of the AX a try. Not sure how but I'll figure it out. Was looking for an older version of the driver on the net to see if I can install that also. Will let you know if either works. Thanks for the suggestion.
- SparxnarxJan 18, 2020Aspirant
Disabling ax worked....your my hero!
- billmy1228Jan 18, 2020Guide
Glad to here. If you mark as solution that could help others.
