mjz
Sep 01, 2020Apprentice
Latest firmware update RAX35 broke wireless on/off scheduling
I updated my RAX35 router with the latest firmware 1.0.3.80 and now my on/off wireless schedule no longer works. I use to be able to turn off the wireless radio in the late evening and then have ...
mjz
I just downgraded to an earlier version. We'll see if that works.
plemans wrote:You could downgrade back a version.
Or try factory resetting (maybe take a backup prior to the reset)
Sep 01, 2020Guru - Experienced User
Let us know!
- mjzSep 02, 2020Apprentice
Well - overnight, the wireless turned off as per schedule, but never turned back on. I'll have to do that manually.
There is definitely something wrong with this router. The NTP time server is working and I did receive email log report (which never worked on the latest firmware, but did on the revision).
At this point, I don't know what else to do. The router is less than a year old (bought last November), so I suppose I can get it replaced under warranty.
plemans wrote:Let us know!
- plemansSep 02, 2020Guru - Experienced User
When you downgraded, did you factory reset and reinstall?
If its a old/bad setting thats crossing over a reset might help.
