BarryD0706
Sep 20, 2025Aspirant
Latest firmware update trashed Access Control
I'm using a RAX120 router (for some years now) and have always used Access Control successfully. A few weeks ago I installed the latest firmware update (V1.2.10.56) and it (or something) has real...
- Sep 20, 2025
Have you tried a factory reset and setup from scratch with a PC and web browser?
What browser are you using?
Sep 20, 2025Guru - Experienced User
BarryD0706
Excellent suggestion! That seems to be just the kick in the pants that it needed. It's behaving well now (at least so far).
I use the Safari browser (as always).
- FURRYe38Sep 21, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
