BarryD0706
Sep 20, 2025Aspirant
Latest firmware update trashed Access Control
I'm using a RAX120 router (for some years now) and have always used Access Control successfully. A few weeks ago I installed the latest firmware update (V1.2.10.56) and it (or something) has real...
- Sep 20, 2025
Have you tried a factory reset and setup from scratch with a PC and web browser?
What browser are you using?
BarryD0706
Excellent suggestion! That seems to be just the kick in the pants that it needed. It's behaving well now (at least so far).
I use the Safari browser (as always).
Sep 21, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
