Firedude302
May 05, 2021Aspirant
Latest RAX120 Firmware (1.0.2.16) Broke WiFi
After updating the firmware from 1.0.2.136 to 1.0.2.16, I found my constantly dropping and reconnecting, then finally quitting with an error stating it could not authenticate the connection. I tried e...
May 05, 2021Guru - Experienced User
One thing to try is when a firmware update breaks something is a factory reset and a clean install (not using a backup).
Reason why is occassionally the firmware changes enough, an old setting can cause issues.
If that doesn't work, then we usually recommend the firmware downgrade.
Chichizola
May 05, 2021Star
Two terms for Netgear Developers:
- Backward Compatibility
- Beta Testing (prior to general public release, that is)
- plemansMay 05, 2021Guru - Experienced User
Chichizola wrote:Two terms for Netgear Developers:
- Backward Compatibility---That'd be great if devices/code didn't change so much. Even the base code from broadcomm/qualcomm changes frequently. Its not just netgear's code that changes in firmware.
- Beta Testing (prior to general public release, that is)----You don't think they beta test? I've been involved in a few tests of devices and occassionally get new firmware to test prior to release. But its a small sample size. But how many devices are sold? Now add in each persons extensive amount of devices they connect. And then you have to ensure the devices that are connecting are coded properly. Its not possible to test every possible combination. Every device maker has this issue. I've had devices that were rock solid and others that were crap. And this is from netgear/tplink/asus/etc. I play with a lot of routers.
- ChichizolaMay 12, 2021Star
Agree with your points. But look at the tickets they are mostly basic, in home installs, no esoteric combination of devices. Their always what side of the prism you choose to look from. I have found much better "luck" with other brands.
