Twitchrot
Dec 31, 2021Star
Latest RAX43 Firmware doesn't work with Safari 15.2
Hi all, My question relates to the RAX43 AX5 WiFi 6 Router and the lastest firmware being V1.0.5.106_2.0.70. When using the latest Safari browser v15.2 on a MAC none of the Advanced settings are...
nielsvds
Jan 01, 2022Luminary
Try this trick in Safari to change your browser agent to see if the web GUI now correctly works : https://wvu.teamdynamix.com/TDClient/1976/Portal/KB/ArticleDet?ID=9681
https://www.howtogeek.com/368817/how-to-view-websites-on-mac-that-require-internet-explorer-or-a-pc/
- TwitchrotJan 01, 2022Star
Hi,
Tried tricking the interface with a different user agents and it doesn't work. Have tried Chrome/FireFox/EDGE and all produce the same result. This is definately appears to be a coding issue which is hopefully resolved soon.
- nielsvdsJan 02, 2022Luminary
You can try to install Edge for Mac and iOS : https://www.lifewire.com/how-to-install-microsoft-edge-for-mac-ios-4173408
That is the only thing you can still try beside changing the user agent that you tried before.
- FURRYe38Jan 02, 2022Guru - Experienced User
Try using FireFox or Opera on Mac?
