Twitchrot
Dec 31, 2021Star
Latest RAX43 Firmware doesn't work with Safari 15.2
Hi all, My question relates to the RAX43 AX5 WiFi 6 Router and the lastest firmware being V1.0.5.106_2.0.70. When using the latest Safari browser v15.2 on a MAC none of the Advanced settings are...
Twitchrot
Jan 01, 2022Star
Hi,
Tried tricking the interface with a different user agents and it doesn't work. Have tried Chrome/FireFox/EDGE and all produce the same result. This is definately appears to be a coding issue which is hopefully resolved soon.
nielsvds
Jan 02, 2022Luminary
You can try to install Edge for Mac and iOS : https://www.lifewire.com/how-to-install-microsoft-edge-for-mac-ios-4173408
That is the only thing you can still try beside changing the user agent that you tried before.
- FURRYe38Jan 02, 2022Guru - Experienced User
Try using FireFox or Opera on Mac?
- TwitchrotJan 02, 2022Star
Hi all,
Shouldn't have to install another browser just to use a product that has been working however it is a valid workaround. The question will be is when will this rectified as this is pretty fundamental issue.
- nielsvdsJan 02, 2022Luminary
I totally agree with you. But it can take a while when fixes,improvements are implemented in a new firmware upgrade. I would also report it to the support.
