Twitchrot
Dec 31, 2021Star
Latest RAX43 Firmware doesn't work with Safari 15.2
Hi all, My question relates to the RAX43 AX5 WiFi 6 Router and the lastest firmware being V1.0.5.106_2.0.70. When using the latest Safari browser v15.2 on a MAC none of the Advanced settings are...
Twitchrot
Jan 08, 2022Star
Hey dmitch77, thanks for raising this with them as it is definetly something on the Netgear side. Looking at your other post and the screenshot I notice the same weird line under the word HOME on the basic tab and whle the cursor will change when you hover over advanced any input like a click is simply ignored.
Hopefully this issue across a number of products will be resolved soon.
amonynuts
Jan 12, 2022Apprentice
I have the same issue (RAX45 with V1.0.5.106), tried using Safari, Chrome, & Firefox. I called and opened a case, and went through the "reset all settings" procedure, but the only solution that Tech Support could come up with is going through the firmware downgrade procedure back to V1.0.2.82 or taking the router back to Costco and buying another one (this time disabling auto-upgrades, or perhaps getting the TP-Link instead).
- amonynutsJan 12, 2022Apprentice
FYI, downgrading my RAX45 to firmware V1.0.4.100 resolved the issue for me.
