Twitchrot
Dec 31, 2021Star
Latest RAX43 Firmware doesn't work with Safari 15.2
Hi all, My question relates to the RAX43 AX5 WiFi 6 Router and the lastest firmware being V1.0.5.106_2.0.70. When using the latest Safari browser v15.2 on a MAC none of the Advanced settings are...
G35flyer
Jan 20, 2022Star
I found a workaround. Once connected to the routers Basic web interface type any junk behind your rounter url....for example: https://192.168.1.1/junk You will get a 404 error, then hit the broswer back button and you can then gain access to the Advanced settings.
- dmitch77Jan 20, 2022Star
That workaround doesn't work for me, using Safari on iPadOS.
- G35flyerJan 21, 2022Star
dmitch77 wrote:That workaround doesn't work for me, using Safari on iPadOS.
The workaround works for me in Safari for iOS, iPadOS and MacOS....here is a screenshot from iPadOS. Not sure why it does not work for you unless you are on different OS version or in the routers case a different firmware version than me.
- TwitchrotJan 21, 2022Star
Hey G35flyer That works a treat on Safari 15.2 on a Mac running Catalina and Monterey. Hope they still fix it as it seems def code related.
Excellent and many thanks! :smileyvery-happy:
- FURRYe38Jan 21, 2022Guru - Experienced User
Does using a different brand browser besides Safari work?
