Twitchrot
Dec 31, 2021Star
Latest RAX43 Firmware doesn't work with Safari 15.2
Hi all, My question relates to the RAX43 AX5 WiFi 6 Router and the lastest firmware being V1.0.5.106_2.0.70. When using the latest Safari browser v15.2 on a MAC none of the Advanced settings are...
G35flyer
Jan 20, 2022Star
I found a workaround. Once connected to the routers Basic web interface type any junk behind your rounter url....for example: https://192.168.1.1/junk You will get a 404 error, then hit the broswer back button and you can then gain access to the Advanced settings.
