Twitchrot
Dec 31, 2021Star
Latest RAX43 Firmware doesn't work with Safari 15.2
Hi all, My question relates to the RAX43 AX5 WiFi 6 Router and the lastest firmware being V1.0.5.106_2.0.70. When using the latest Safari browser v15.2 on a MAC none of the Advanced settings are...
Twitchrot
Apr 02, 2022Star
Hi all,
So the latest firmware for the RAX43 which is V1.0.10.110_2.0.75 still doesn't fix the issue using Safari 15.4 on MacOS (Monterey 12.3.1).
The Advanced Tab/Options are still unavailable even when clicking, trying to open in a new window or trying a different user agent.
It would be nice to understand the issue behind this from Netgear's point of view. Here we are in April, two firmware releases later and no one has bothered to address a fairly straight forward and fundamental issue. The beta firmware prior to V1.0.10.110_2.0.75 addressed the problem yet it doesn't make it into the next release candidate.
I do find it incredulous that Netgear cannot fix this issue as it would seem loyalty doesn't mean anything however, the bottom line does.
While I have wasted heaps of time on this issue I don't plan on giving up because I paid for a product that I expect to work!
amonynuts
Apr 04, 2022Apprentice
fyi For the same issue on RAX45, I called Netgear support and filed an issue in January, within 60 minutes of buying the router. The case is still open, but apparently Netgear has a fix, just waiting anxiously for it's release. In the meantime, browsing to "http://routerlogin.net/junk" after logging in, and then hitting the back button, is at least a good temporary workaround on my iphone.
