Dvalin21
Jan 23, 2023Aspirant
Latest Update causing dead ports for the AX1800 Wifi Router R6700AX
You know this router has been ok at best which I have just dealt with for a few years. I didn't listen to the notion to get a new router. And after this firmware update that recently came in, it only...
Jan 24, 2023Guru - Experienced User
After the firmware upgrade, did you try a factory reset?
One of the first things we recommend if there's issues after upgrading firmware.
If that didn't help, you could try doing a manual reinstall. If you installed via the app or over wireless, its usually where we see corrupt firmware issues. Maybe that happened to yours and a reinstall of the firmware will help.
And if that doesn't help, just downgrade it back to the prior version.
