gpopm55
Jan 12, 2022Aspirant
LED lights
i just installed my new router but the ethernet LED does not come on. is this normal?
Jan 12, 2022Guru
What router did you install?
What are all the other led's doing?
Is it having issues?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
