gpopm55
Jan 12, 2022Aspirant
LED lights
i just installed my new router but the ethernet LED does not come on. is this normal?
Jan 12, 2022Guru - Experienced User
What router did you install?
What are all the other led's doing?
Is it having issues?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
