domerdel
May 29, 2024Follower
LG TV connects to iPhone hotspot... refuses internet access to Nighthawk RAX80
Router Setup Running Firmware Version V1.0.10.140_1.0.79 enabled 2.4Ghz and 5 Ghz - both are WPA2-PSK (AES) Enabled AX (only 5 G has the OFDMA) NAT filtering set to Secured (Default) No parenta...
May 30, 2024Guru - Experienced User
Try putting the att gateway in router mode (disable its wifi) and the netgear router in AP mode.
