Nano_Pico
Jun 05, 2020Guide
Link Aggregation Race Conditions RAX200 and SB8200
I just purchased the RAX200 and have configured it for link aggregation with the SB8200. When running properly I achieve download speeds of 1.2 Gigs. Every 24 hours or so the download speeds gor to...
Jun 09, 2020Guru - Experienced User
I wouldn't use the link aggregation with the sb8200.
Disable it and use the gigabit connection. You loose the over provisioning from your isp but you're connection will be more stable.
Arris is aware of the issue with the SB8200.
Nano_Pico
Jun 14, 2020Guide
Yes, the link is very stable if the WAN LAG is disabled on the RAX200
