blarochelle
Aug 23, 2022Tutor
Location of Router Issue or Not
I am planning to locate my router on a chrome steel rack in my living room. These are the kind of racks you would normally use in the kitchen. I was wondering if anyone could tell me if the metal rack...
Aug 23, 2022Guru - Experienced User
Steel does a great job of blocking wifi. But routers broadcast omnidirection so its more an issue of what's directionally on the other side of the rack. Tough to know plus if the rack is a plate style or rod style.
- blarochelleAug 23, 2022TutorThanks for replying to my question! My router is on a wire rack, as pictured in the attachment. There is nothing behind it, and honestly, the transmission needs to go out and up from the living room to the upstairs bedrooms.
- plemansAug 23, 2022Guru - Experienced User
You should be fine with that. I've used something like that and the dissipation patterns shouldn't cause an issue.. (depending on whats below it). Not 100% saying it won't be an issue but I've used something similar and it worked fine.
Thanks for the reply! I didn't think there would be much of an issue, as there really isn't that much metal involved. I mean, it's not like this is a faraday cage. I'm going to go ahead and install and run some network stats on the shelf and off the shelf. I appreciate your feedback!
