blarochelle
Aug 23, 2022Tutor
Location of Router Issue or Not
I am planning to locate my router on a chrome steel rack in my living room. These are the kind of racks you would normally use in the kitchen. I was wondering if anyone could tell me if the metal rack...
blarochelle
Aug 23, 2022Tutor
Thanks for replying to my question! My router is on a wire rack, as pictured in the attachment. There is nothing behind it, and honestly, the transmission needs to go out and up from the living room to the upstairs bedrooms.
Aug 23, 2022Guru - Experienced User
You should be fine with that. I've used something like that and the dissipation patterns shouldn't cause an issue.. (depending on whats below it). Not 100% saying it won't be an issue but I've used something similar and it worked fine.
- blarochelleAug 23, 2022Tutor
Thanks for the reply! I didn't think there would be much of an issue, as there really isn't that much metal involved. I mean, it's not like this is a faraday cage. I'm going to go ahead and install and run some network stats on the shelf and off the shelf. I appreciate your feedback!
- plemansAug 24, 2022Guru - Experienced User
Let me know how the speed testing with/without it goes.
I'd be interested to see if it impacts it. I didn't test mine but it seemed to work fine.
