Newfiedrool's avatar
Newfiedrool
Virtuoso
Jan 16, 2020
Log files bug on RAX120
Hi
I have recently purchased the RAX120 and I've been watching the logs carefully and I've noticed after about five days all details of Dos attacks and port scans disappear.
I'm guessing this is a bug and I thought I would post to see if anyone else is suffering this issue and to maybe bring it to attention so maybe it can be corrected at some point of time.
  • Is it just that old entries are disappearing, or that only lines here and there are disappearing?
    If the first, I would blame a common bug (R7800 does same thing).  If the later, then I don't know.
    • Newfiedrool's avatar
      Newfiedrool
      Virtuoso
      All dos attacks and scans simply don't show after about 5 days on the logs. Up to five days it's showing them.
      ive rebooted the router and set logs to be sent to me, after the reboots it's showing me dosattacks and scans but this will stop and I'll catch the exact time again when it happens.
      • michaelkenward's avatar
        michaelkenward
        Logs are limited in how much data they can hold. As they fill they will drop old details.
        Just what gets logged and what happens is for you to decide in the settings.
        In most routers there is an option to get the logs sent to you by email.
        By the way, most logs of dosattacks are "false positives".
        I leave it to you to search this community for the many previous conversations about this.
