Newfiedrool
Jan 16, 2020Virtuoso
Log files bug on RAX120
Hi I have recently purchased the RAX120 and I've been watching the logs carefully and I've noticed after about five days all details of Dos attacks and port scans disappear. I'm guessing this is...
michaelkenward
Jan 17, 2020Guru - Experienced User
Logs are limited in how much data they can hold. As they fill they will drop old details.
Just what gets logged and what happens is for you to decide in the settings.
In most routers there is an option to get the logs sent to you by email.
By the way, most logs of dosattacks are "false positives".
I leave it to you to search this community for the many previous conversations about this.
Killhippie
Jan 17, 2020Prodigy
I have raised this as a bug with support because the logs are not dropping off as they should on the RAX120 on 1.0.1.108 I have all of mine mine from the last time I rebooted it which is 22 or so days ago and it says initialise firmware etc and after a few days the known port scan and DoS logs stop being logged completely, but the rest continue and the logfile just grows huge with weeks of dats but no port scan or DoS logs, I even tried a sheilds up port scan which shold show upo, and does when the router is first rebooted but after a few days even running that wont get port scan and DoS logs to show. It started for me with the current version even after factory reset, Its been reported to Netgear now. 1.0.0.84 works fine log wise.
- duckwareJan 18, 2020Prodigy
If anyone is interested in a Win program that pulls down Netgear log files, contact me (follow link at bottom of duckware.com/wifi)
